It is currently Fri Aug 15, 2025 2:18 pm
PostPosted: Thu Nov 13, 2014 7:04 pm
Last Name: Beaver
City: Lake Forest
I'm planning to switch to a nitro lacquer on my next build. Cardinal looks interesting. Any thoughts or experiences with it? How would you rate it compared to other nitro lacquers?
Joe Beaver
Maker of Sawdust
PostPosted: Thu Nov 13, 2014 11:37 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I used it on 1 guitar and it works fine, the nice thing is it can be level sanded and buffed much sooner than most lacquers and less time between coats. It is at a ready to spray viscosity, but is lower in solids so needs more coats to establish the build up you are accustomed to. I will use up the rest of the gallon I have and the Mohawk I have on hand then decide if I will purchase any more or continue with Mohawk..
Fred
Fred Tellier
PostPosted: Fri Nov 14, 2014 1:47 am
Last Name: Beaver
City: Lake Forest
Sounds good Fred.
A couple questions if you don't mind. I use a conventional spray gun, any ideas on tip size? Also I like to use epoxy for pore filling. Should I use their sealer over the epoxy and under the lacquer? Any guidance is appreciated.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Nov 14, 2014 1:48 am
Last Name: Beaver
City: Lake Forest
Double Post
Joe Beaver
Maker of Sawdust
PostPosted: Fri Nov 14, 2014 6:56 am
Absolutely nothing wrong with Mohawk. Price is right too.
PostPosted: Fri Nov 14, 2014 8:20 am
State: ON
Joe Beaver wrote:
Sounds good Fred.
I'm another Mohawk user. I fill with z-poxy and seal with schellac. I've noticed it buffs out nicer after 3 weeks dry time minimum.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Fri Nov 14, 2014 9:25 am
First name: Fred
Last Name: Tellier
City: Windsor
I use a Devilbiss starting line touchup gun with a 1 mm tip for the Cardinal and Mohawk. The reason I sprayed the Cardinal is a client did some research on Mohawk and read about the amber characteristics and did not want that to happen on his quilt maple build.
Fred
Fred Tellier
PostPosted: Fri Nov 14, 2014 12:54 pm
Last Name: Beaver
City: Lake Forest
Thanks guys. Good info. I also use a devilbiss gun. I'm pretty sure my tip is bigger than that I'll have to check it out. I never considered the ambering effect.good info
Joe Beaver
Maker of Sawdust
PostPosted: Fri Nov 14, 2014 3:44 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
Joe Beaver wrote:
Sounds good Fred.
I have used Cardinal for my last 12 or so guitars. I like it a lot. I use a 1.2 mm tip and pore fill with System 3 SB112 epoxy. I use Cardinal sealer over the epoxy and under the lacquer.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Fri Nov 14, 2014 8:00 pm
Last Name: Beaver
City: Lake Forest
Tim,
Thanks for that. If it works for you it ought to work for me. Sounds just like what I need to do!!!
Joe Beaver
Maker of Sawdust
Users browsing this forum: rbuddy and 17 guests
